My hummingbird 565 screen turned white I have depth & temp but not right .simulator mode works .Is it the unit or transducer
SOURCE: Hello, my Humminbird 565 startred to misread the
More than likely you have your sensor run underneath the boat and therefore the sensor is directly in the water. When you speed around the hot water on top is what your sensor is picking up, when you slow, you are allowing the sensor to pick up on the colder water just inches below the surface
SOURCE: My 570 quit showing the depth and continues to
I had the same problem. It was the transducer.
SOURCE: I have my Humminbird fishfinder
I would contact our customer service group and they will be able to help you. Our number is 800-633-1468.
SOURCE: I have a humminbird pmax 170. It does not show
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
SOURCE: I have a Eagle cuda
Hi, First check the Battery status of your Fish finder, replace
the battery. Check the transducer and suction-cap. Master reset after replacing
of battery may need for your fish finder. It can solve your problem.
