Onkyo TX-8511 Receiver Logo
Posted on Aug 28, 2007
Onkyo tx-sr800 PROTECT mode
How can i reset my receiver out of PROTECT mode
  • Befuttled Nov 16, 2007
    I have a new TXSR705. I received it yesterday. After hooking up all the components I cannot keep the receiver running. It will run for awhile and click off. It does not say protect but the standby button blinks. I have checked all my connections several times. I am at my wits end. Please help.
A
Anonymous
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
My ONKYO tx 8511 is protect mode How to reset
Hi Vinoth, if this has not been resolved I would advise you to disconnect the unit from the AC Outlet for at least an hour and then see if it is out of Protect Mode, Thanks, JT
My receiver is in protect mode..what does that mean
See reasons for protect mode on onkyo site.
Most likely the speaker wires are shorting or are reverse polarity. see connection diagram.
My onkyo tx-sr800 powers up and just when you think there should be sound it cuts off. whats up with that??
Sounds like it is failing its self test so it won't try to power anything. First step would be to disconnect the speakers, turn the volume control all the way down, then power it up. If it comes up OK, then you've got a wiring issue or a short in one of the speakers. If it still doesn't come up OK, then there is an internal issue in the circuitry - most likely the power amp, any you'll need professional repair help.
12helpful
2answers
2answers
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
TX-SR800 circuitry protection activated
You maybe got to change the ICs audio amplifiers of the receiver they are damaged.
1helpful
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
1helpful
3answers
Onkyo tx-sv535
when the apm in protect mode means it is problem in inside.don't trow it please repair it n use
3helpful
2answers
Stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
