Please let me know more information, what I think has happened is that you dropped the phone in water and now it is turning on but you get a network problem constantly. If that is the case...
It is probably your phone's SIM card that has been damaged by the water. Go to your phone store or call customer service to get a new SIM.
If the new SIM doesn't solve the issue your phone has been damaged and may be unfixable. But, before you give up, get that new SIM.
If your cell phone is damaged by water follow these instruction
1. Remove The Battery Immediately 2.clean your battery with a towel or paper and let it dry 3.Use air to force out the water from your mobile phone 4.else you can put your phone in a bag or dry rice over night so that in morning the water will be absorbed by the rice from the cell phone 5.now put the battery in the cell phone and try to switch it on 6.There are chances that the mobile get turned on.sometimes if the circuit is entirely damaged its impossible to recover.. I hope this will help you.if this helps you rate this answer thanks and regards Lalith
Ahhh, sounds like your cell phone may have been water damaged, you may have to get a new phone. To assure it's water damage (i can't help you then) take the back off your phone and remove the battery. Under there you will see a sticker, if its red at all its water damaged. If it's white message me privately and i can help debug from there
Unfortunately you have no chance. You're very lucky that the flooded phone worked for so long afterwards, but the water will have left conductive residues as it dried out and these have effectively fried your phone.
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone. Razr V3 external battery charger
May be the phone was water damaged. This kind of problems normally we see in water damaged phones. If not water damaged then PA (Power Amplifier) may be shorted and need to be changed.
Turn your phone off for at least a day. Dry off your phone if you haven't already. Take out the battery, dry out the inside of the phone. If you have a sim card, take that out and leave to dry. Leave the battery out of the phone for a day as well. Put it back together after a day and try to power it on. If it doesn't come on, try plugging it in without the battery in. If it works that way, you simply need a new battery.
If this doesn't work you're probably going to have to get a new phone. Your cell phone provider will be able to tell if it's water damaged, so check with them to see if they replace water damaged phones.
