Question about Fossil AM3425 Wrist Watch
Fossil ch 2356 battery size - Fossil AM3425 Wrist Watch
Which 3 battery sizes go in fossil BG2131 watch?
Take your Fossil watch to a jeweler who will identify the battery type and may even be persuaded to install replacements. All for a reasonable sum.
May 24, 2018 | Fossil Watches
Ch-2331 battery replacement for fossil blue
Take your watch to a jeweler for battery replacement.
Jan 30, 2017 | Fossil Watches
Battery for Fossil CH-2510
Take your watch to a jeweler to replace it.
May 28, 2014 | Fossil Metal Chronograph Cavalier CH2464...
INSTRUCTION MANUAL FOR FOSSIL CH2698
See https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_US.pdf
The file is a compendium of instructions for a large number of Fossil movements, but it is unclertain which movements the model CH-2331 and CH-2698 watches use. However, movement OS10 (page 15) appears to be the only one that matches the dial layout, button layout and also has a date window as the CH-2331. The watch has a quartz analog mechanism and uses one SR927W 1.55-volt silver oxide button cell. Silver oxide cells have low current output, but very long shelf life, so if the stem is pulled out completely when the watch isn't being worn, the battery could last many years. Scan the instructions to match up the CH-2698 with a movement number. A good guess from examining photos of the face of a CH-2698 watch would be movements OS20 / FS00 or VD53.
Apr 07, 2014 | Fossil CH2331 Wrist Watch
What type of battery for a fossil ch-2532
Take your watch to a jeweler to identify type and possibly replace it.
Mar 01, 2014 | Fossil CH2331 Wrist Watch
Fossil CH-2601 251004 BATTERY
Take your Fossil watch to a jeweler for identification of the battery and possible replacement.
Jun 20, 2012 | Fossil Watches
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
Aug 26, 2010 | Fossil AM3784 Wrist Watch
Trouble sizing Fossil Watch CH-2506
Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
Jan 02, 2009 | Fossil Chronograph Urban White Dial CH2506...
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil AM3425 Wrist Watch Logo
164 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
