My remote control for my JVC t.v. wont work any longer, I have a older RCA universal remote, my question is how do I get it to work my JVC t.v? Thank you,
This is the eastest way to program your remote.
To program a component using the Automatic Code Search method, perform the following steps:
1.
Turn on the component you want the remote control to operate.
2.
Press and release the component button that corresponds to the component you want the remote control to operate.
The illuminated ON-OFF button turns on and remains on.
3.
Press and hold both the component and ON-OFF buttons.
RCA universal remote - info.gifg src="/uploads/images/info.gif" alt="info.gif" class="h_mi" />
The illuminated ON-OFF button turns off.
4.
After the illuminated ON-OFF button turns back on, reRCA universal remote - info.gifth buttons.
The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained.
5.
Press andRCA universal remote - aud_remote_play.gifPLAY button.
6.
If, after five seconds, the component does not respond, continue to press the PLRCA universal remote - info.gifn>button every five seconds until the component turns off.
Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
7.
When the component turns off, press and release the
how do i program this remote
need codes
Universal Remote Control
