It would be easier to change the 220 circuit in your house to a 110 by some creative work in the breaker panel and making it an air condtioner circuit only. You would need to check with an electrician, but would probably be worth it in the long run.
Then you might be able to use an converter as you can't change apartment wiring. Google OHMS law and it gives you the equations to figure out watts, volts, amps, etc. You just need a calculator. It's the amps that trips the breaker. Another solution would be to run an extension cord rated for the amperage from a less used circuit.
rental apartment
