Took this amp out of my car and everything was good. It sat for awhile and then tried to install it in a friends car. When the amp was first installed everything was good,Power came on,subs where working,then it started blowing fuses at the amp. And continues to blow fuses. Went through all the wiring and even took amp out and wired it straight to another battery direct.Amp Keeps blowing fuses. PLEASE HELP!!!!!!!!!!!!!!
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Please check your voltage comng in with a volt meter. Not a test light. You need to verify true vol
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Make sure that the speaker wires are wired correct at both the amp and the speakers......otherwise it sounds like the typical death of a power acoustik amp (great amps, but prone to a premature death)
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
