Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki 650 brute force won't start
Starter turns but motor won'crank over. I've taken the starter out and tested it on the bench, it is working fine. I have also cleaned all the connections on the battery and the starter.
  • fishinbuddy4 Mar 30, 2009
    I can start the motor with the pull cord easily, and it runs smooth
Sounds like to me that your motor is locked up, take the CVT cover off and see if you can turn the primary clutch with your hands. If your not able to turn the primary clutch, then the motor is locked up. Good Luck.
Posted on Mar 29, 2009
SOURCE:
Just replaced starter motor. Flywheel has all its teeth and so did the old starter motor. Fuses look good. The starter is rotating but the engine will not turn over and start. whirring noise.
check that the pinion of the starter is engaging the flywheel teeth
check that the over run clutch of the pinion is engaging and not over running when it is supposed to lock up to turn the flywheel
Jan 14, 2016 | kawasaki 2009 Brute Force 750 4x4i
Why won't it start?
Check the starter to see if it is engaging the flywheel. There may be a flat spot on the flywheel so the starter cannot mesh with the teeth on the flywheel.
Dec 31, 2015 | kawasaki 2009 Brute Force 750 4x4i
How do I determine the problem when the starter won't turn over until I pull the rope, then it start AOK until the next time???
Automobile starter repair shops have a test set-up and can test any starter with it. If the solenoid is bad, they can tell you. The most common fault is a clicking sound when not starting, but that isn't the only fault. A common fault is a loose ground wire or short, but since your starts with a pull, then that appears unlikely in your case or it wouldn't start at all. Good luck.
Feb 25, 2015 | kawasaki 2005 Brute Force 750 4x4i
When you turn the ignition and it clicks but will not turn over and the lights still work what could it be
low battery, battery cables not making secure connection, battery terminals oxidized or needing cleaning/brushing .... failed starter .... tap the starter with a wrench, it can revive it :)
Feb 23, 2015 | 2004 Ford Freestar
Have a 2007 Kawasaki 650i with 100 hrs on it. Starter acts up periodically. Just the cellinoid cliks. Has new battery, checked the cellinoid and it is closing. Checked voltage to starter and it is proper...
When you say you checked the starter, did you check it under load? A "bad" starter " often will turn when it's out of the vehicle and hooked up to a battery. That doesn't always mean it's good. When you take a starter to Auto Zone or Advance they check it under a dummy load to simulate the load the starter is under when it turns an engine. So if you checked the starter under load, then it is OK. If you didn't , take it Auto Zone or Advance and they'll check it for you.
May 29, 2014 | kawasaki 2007 Brute Force 650 4x4
2000 Kawasaki ZX-6R Ninja will not turn over
Hi, Mike before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
98 zx6r won start turn over nothing KawiForums Kawasaki Motorcycle Forums
2003 ZX6R Won Start 1 Engine Won Turn Over
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 25, 2013 | 2000 kawasaki ZX-6R Ninja
Kawasaki brute force 750 cranks over then locks up it won't turn over by pulling the rope
sound to me you got faulty security switch check them 1st, specially the kick stand, most bike locks up if you try to place it in gears while the kick stand is still on. hope it helps
Dec 24, 2012 | Motorcycles
Kawasaki 650 brut force is not starting when pushing the starter button, will not turn over?
Your starter button may need to be replaced or taken apart and clean up the contacts
Oct 11, 2010 | 2003 kawasaki W 650
1989 650 jet ski starter drive spins but not turning motor,drive is working fine when removed.
it is probably too wore out to crank the engine. replace brushes and bearings or find a new starter.
Sep 30, 2009 | 1977 kawasaki Z 650
kawasaki Full Suspension Mountain Bike Men Logo
839 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Steve Worthey
Wayne McNeil
Warren Kareroa
Warren Kareroa
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
