Panasonic TH-46PZ80U model Viera Plasma TV, 46 Viewable Image Size, 1920 x 1080 Resolution, Plasma Technology, 1080p Display Format, 16:9 Image Aspect Ratio, 20000:1 Image Contrast Ratio, 1000000:1 Dynamic Contrast Ratio, Progressive Scan, 0.53 x 0.53mm Pixel  Logo
Anonymous Posted on Jul 16, 2013
Panasonic TH 46PZ80U has light blinking 10 times then repeats. Any thoughts
Dayton Computer
Level 3:
  • Panasonic Master 1,640 Answers
  • Posted on Jan 22, 2015
Dayton Computer
Panasonic Master
Level 3:
Answers
1640
Questions
0
Helped
819187
Points
6396
Yes...it seems it blinks 10 times
8 BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
PANASONIC TV MODEL # TH-46PZ80U BLINKS 10 TIMES
had the same problem with my panasonic, it was a faulty power switch, its a common fault with them
1helpful
Th-46pz80u 10 blinks red light
Power supply or something loading it down.
1helpful
2answers
Tv will not turn on
Hi, I have 10 blinks. Any thoughts? Thanks
4helpful
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
5helpful
3answers
Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
