I have "Intel PRO wireless 2915abg 2200bg Network" driver installed but i need "Microsoft Virtual WiFi Miniport" adapter so i can share internet with my android phone please can anyone help me to find this? or is it not possible to get that on my laptop?
Kemar,
Click the link below to view the youtube video on how to turn your windows 7 laptop into a MS Virtual Wfi hotspot.
http://dell.to/13mQJV6
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: wifi problem on dell inspiron 6000
Check the driver properties and make sure it is not turning off when idle. You could have router issues. Are you using a wireless router of your own? Are you putting in the password for the connection. I could go on and on about wireless problems. Wireless does not just pull the Internet out of the AIR like some people think. Get someone to help you that can use wireless and compare settings.
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
SOURCE: physical network adapter not installed?
It may have come loose in the slot. On most Dell laptops, the wireless car is located on the bottom of the laptop. There will be a small square cover secured by one screw. Remove the screw and plate to see the card. There will be two wires connected to the card. These are the antennas. There will also be two retaining clips, one on each side. Release the clips and the card will pop up on one end. The opposite end will be in the slot. Pull it out and then re-seat it firmly in the slot. Replace the cover and secure it with the screw. Turn on the laptop and see if the card is identified.
Good luck, and please let me know how this works out for you.
~ Spoem
SOURCE: my drivers on my dell inspiron 1705 are having
try re-installing the drivers of these....if that does not work
check this
device manager/network adaptor/ur netwrokd card/properties/resources
check if that has any 'Conflicting Devices"
check if the IRQ # is not frozen
under the General Tab check if the Device Status is working properly etc
