Kenwood Chef Major A701 Food Mixer Logo
Anonymous Posted on Jul 15, 2013
Serice manual can anyone let me have a service manual I specifically want to repair the clutch in the top I cant even get the top cover off Thanks Rob
  • Anonymous Jul 18, 2013
    Just to clarify, I have a kenwood chef a701. Can anyone let me have a service manual for it.
Kelly Romain
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jul 31, 2013
Kelly Romain
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
4635
Points
10
I have an A7xx that I recently repacked (gear housing). Send e-mail specifically for steps in disassembly. I have pics posted on my facebook pages of same
I have a KitchenAid 5qt lift bowl mixer from 2000 and have burned out the motor. Can it be repaired or should I just spend the money on a new one?
Without knowing which model mixer you have I cannot be specific as there are 5qt models with very different motors. Parts are available and the mixer can be fixed. Doing it yourself makes it much more affordable.
Service Manuals covering the two types can be found at:
Professional 5/6 quart:
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
4.5/5 quart:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
I just replaced the worm gear in my Kitchenaid model ksm500pssm stand mixer. Now it only turns on when speed is set to 9 or 10. What might I have done wrong?
This is most likely has to do with either or both the control plate and control link. If the spring which goes from the control link to the control plate is not connected, the power to the motor will not turn on properly. This is most likely the source of your problem.
Take a look at the Service Manual which covers your mixer (even though it may not specifically reference your model):
Why kitchen aid mixer wont turn on
Any number of reasons such as:
Bad electric cord
Bad brush or brushes
Bad armature or stator
Control plate broken
You need the Service Manual:
While this manual does not cover the Artisan specifically, the procedures do apply.
Service manual needed for kenwood mixer 901
Hi Mikey. No, I don't have the manual but email me at [email protected] if you have any specific questions. I repair quiet a few of these.
SERVICE MANUAL FOR KENWOOD CHEF A701A
Hi Alfred. I don't have the manual but I have repaired dozens of these machines. Do you have a specific question?
May 10, 2013 • Food Mixers
Have an A901E model and there is oil leaking from the head, does anyone have a repair manual, so that I can figure out how to repair it?
My chef A901 started to smell and leak oil. I started to dismantle it but found that a service manual is needed. Kenwood will not supply this for "Health an safety" reasons. can anyone help please.
2answers
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
1helpful
Older Kitchenaid mixer has lost the two top speeds
Hi Leslie. www.mendingshed.com has a Kitchenaid Repair Manual available for a free download. If you're going to attempt a repair yourself, this manual will come in handy. You haven't said what model of mixer you have, so I'm only able to guess that this manual will cover your needs.
If this solution has assisted you, please rate it. Good luck! ricardok45
2helpful
Mixer part not rotating
Have recently inherited an old Kenwood Major A707A with same problem, contacted local electrical repair man, experienced with Kenwood mixers. He is fitting a new clutch, will cost about £30. I think its worth it. Anyone out there know where I can get Instruction Manual ?
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
