I turn my tv on with the remote, so I see the red light turn green. Then just as the tv screen comes up you see the white light pop up on the screen it immediately shuts off. Back to a red light again. For some reason it won't come on or stay on. It just started this 2 nights ago, it happened once and I thought I just never turned it on. I thought I maybe didn't have the remote in a spot for the tv to grab the signal. So I tried to turn it on again and it stayed on. But then last night I realized it has a problem becuase it won't stay on at all now. Model 3200
SOURCE: Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
SOURCE: aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the
42nd leg it shuold be 13 volts dc if you are not getting that voltage
replace the microchip.and the eeprom IC....
thank u rate me!!
SOURCE: Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
SOURCE: Protron PLTV-32C, Model No. LT32C1P1 just went
Mother board Is My Guess That's What's Wrong With Mine And Part Is $250.00 My Problem IS Can I Replace it By Myeslf . I Had Mine looked At .By So Called Professional He Kept it For 8 Months.
