Question about Honda HRX217VKA Lawnmower
Smart drive cable on a honda hrr lawnmower
I took the "smart drive" paddles apart and now I can't seem to get it back together and working. Is there a secret way to reassemble this crazy thing?
3 Suggested Answers
SOURCE:
SOURCE: drive wheels on my honda hrr 216 wont free wheel
Take the rear wheels off and clean parts 2 to 7
http://www.searspartsdirect.com/partsdirect/part-model/Honda-Parts/Walk-behind-lawn-mower-Parts/Model-HRR216/1795/1500600/P0510128/00002
You may need to replace 5,6,7
Posted on Apr 03, 2011
SOURCE: I have a Honda engine in my push moser. I can get
Thr air mixture needs to be adjusted. Turn screw in all the way then back off one and a half turns
Posted on May 13, 2012
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Honda self propelled lawnmower hrr.it want run unless u manually put gas in carberater.so does this mean I have to rebuild it
Remove the bowl by removing one bolt from directly underneath it. The bowl is a silver metal cylinder shaped piece.
After removal, you will see a small almost pin sized hole. It is probley clogged up. Take a needle, small nail, anything that you can insert into the hole to clean out. Also blow through the hole.
You may need to repeat this a couple times but it will work!
/uploads/images/9_5_2014_6_12_42_pm.jpg
/uploads/images/9_5_2014_6_13_37_pm.jpg
Sep 04, 2014 | Garden
Its not working for me plz help. Bush 40inch smart tv remote is not working
Did you ever get the remote control wet? If so it can be taken apart and cleaned of any sugary contamination with water, a drop of soap and a toothbrush... dry and then put back together. If it is imperfect crazy glue foil to the bad buttons
Oct 21, 2013 | Televison & Video
How can I get blueprints to put back together a 2007 Troybuilt Pony riding lawnmower? It needed several parts. They've all been purchased and replaced, however, putting the thing back together is like...
Can you get model, serial and year? There should be a tag or plate near or under the seat with this info. I should be able to get diagrams for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 04, 2013 | Garden
Took washer apart, put it back together and now it won't start
ok... seems that it is trying to fill but wont...first...for all problems after dis-assembly of anything...I always recheck all wire connections...yould be amazed how a wire can be pulled off and you not notice it...next...if they are all tight...next ensure your water supply is turned back on at the faucet....try unplugging the unit from the wall, waiting 5-6 mins and plug it back in..to see if the controls reset..phillip
Jul 04, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I took my desktop apart and put it back together and now it won turn on
Open it back up and check to make sure you didn't accidentally pull one of the cables out.
Jun 30, 2012 | Dell Computers & Internet
Black and Decker BV4000 type 2 blower switch reassembly?
In case anyone searches this topic (like I did), because I really love this machine (now in its 8th year of service with me), here are some pictures to assist in reassembly so the plastic bits connected to the thumb control actually touch and engage the rocker switch. The type 3 was not recalled (yet) so I jumped the thermal breaker (and I'm watchful now, but not fearful).
  • Pic #1 is the picture of the whole switch assembly, ready to put the housing back together. Notice the gap between the plastic bit and the rocker.
  • Pic #2 is a close up of that same situation (gap is still there)
  • Pic #3 is how to reassemble it. The key is to apply just enough pressure with a skinny flathead screwdriver to push the plastic bit up against the rocker and HOLD IT THERE while you are reassembling the housing, and until you torque down all of the screws.
It is this pressure that keeps it in place. I had my wife hold the screwdriver while I reassembled it. Voila! At least one more season of service :) But, be careful when you use it the first time- make sure the safety that prevents it from running while you change the blower pieces works or you may be in for a surprise!
black-decker-bv4000-type-2-blower-switch-cpvihq5biqol3jnxulxmklnm-1-1.jpg black-decker-bv4000-type-2-blower-switch-cpvihq5biqol3jnxulxmklnm-1-3.jpg black-decker-bv4000-type-2-blower-switch-cpvihq5biqol3jnxulxmklnm-1-6.jpg
Apr 14, 2012 | Garden
If I take a coolpix s4000 apart and put it back together will it still work afterwards
That depends on why it wasn't working before. If there was a bad component, disassembling and reassembling won't change a thing. If there was a bad connection, reassembly may fix it.
Feb 28, 2012 | Cameras
Honda HRX217VKA Lawnmower Logo
47 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
