SOURCE: I installed the CD for Jumpstart Spanish 1st-3rd
To fix, try this
Right-click on My Computer icon, and select Properties.
Click on the Advanced tab,
then select the Settings button within the Performance section.
In the Performance Options window, click on the Advanced tab, and then select the Change button in the Virtual Memory section.
Click the Custom size button...
Change the Initial size (MB) setting to 4000
Change the Maximum size (MB) setting to 4000
Select SET to accept the change, which will close the Virtual Memory window. Select OK to close the Performance Options window. And select OK to exit the System Properties window.
please rate my solution
have a nice day.
SOURCE: Installing the jumpstart advanced 1stgrade cd rom
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
SOURCE: How to delete names on Jump Start Advanced 1st
The Knowledge Adventure page makes this suggestion:
Recommendations:
· JumpStart: Most of the JumpStart programs
have a keystroke combination like CTRL+D+D to delete
one user at a time from the sign in screen. See
the manual for more information regarding the software.
Other JumpStart programs have a delete button directly
on the sign in screen.
CTRL+D+D didn't work for me on JumpStart Kindergarten, but CTRL+ Delete did!
