Your on a worldwide chat room, asking for a radio security code that no one would have or should have If you even need a code & I would guess a 1994 is too old for a dealer to help, but they may have the answer
We just unlocked a 98 Volvo S-70 radio,on the front,you have 2 slots across from each other,use you finger nails or a dime to get it to come out,then you can pull it out,then get the serial number and write it down,then put stereo back in,then get your vin number,it's on your insurance card,then call dealer and ask for your radio code,they will ask for vin number and radio serial code,if your radio says code,then you can enter it,ifit says off,then it's locked,you have 3 tries till it locks and it says off,if it says off,then you turn key to number 1,turn radio on,wait 2 hours,then it will say code,then enter code and radio will unlock,our code is 5513 if you want to see if it will work for you.Here's a link to you owners manual,read about the radio code,same as our's,but the dealer will give it to you free. 1994 Volvo 850 Watch this video. How To Find Volvo Radio Code 850 960 S70 C70 etc
You will need to turn the ignition to the number 1 position and turn the radio on. It can take several hours, but the word code should come back on. When that happens, you will need to put the correct code in. If you don't have it, a Volvo dealer can give you the correct code from your VIN.
if the vin no may not be able to help, pull out the radio set and get the serial nos and together with it, get your local Volvo dealer to obtain the code. I did mine in Malaysia at no charge.
The code might be written in you owners manual/warrenty booklet. Its usally 4 numbers. Also if you pop out the radio the code could be on the radio itself, if not call the dealer with the radio out and give them the serial #
remove radio by pushing in the two side tabs to alow you to remove. Call your local volvo dealer (parts dept.) with the serial # and part # off the radio. Type in the code and volia.
call your local volvo dealer and tell them your battery went dead and that you need radio code. they will ask you for car VIN...dont go that route, pull out radio and give them the numbers on the sticker ontop of radio. and make sure you keep the code written down. Good luck.
