How do i change my language from arabic to english
trying to change language from Arabic to english - Settings -Where is the system tab to regional setting - is there a symbol?
From regional option, change stardard and formats to Arabic and from location change it to saudi arabia
Go to advanced, change the language to arabic
After these restart your computer to take effects.
If not working, you need to install arabic laguage support and repeat the procedure above to activate the arabic by pressing Alt plus shift key to change the writing from english to arabic or same to go back to english writing
reinstall service pack 3 with language pack from microsoft.Make sure you back up your registry first. For xample
If you have XP SP2 in ENG and want to have it iArabic, you will have toDownload SP3 in Arabic (http://www.Microsoft.Com/downloads/details.Aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
change language to desired one then download), change some registry
Keys (go to
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language Registry
Key, and then change the value date for “Default” and“InstallLanguage”
Registry value from 0001to 4001) reboot and you'll be able toInstall
SP3 in
Italian.
0001 = "ar;Arabic"
0401 = "ar-sa;Arabic (Saudi Arabia)"
0801 = "ar-iq;Arabic (Iraq)"
0C01 = "ar-eg;Arabic (Egypt)"
1001 = "ar-ly;Arabic (Libya)"
1401 = "ar-dz;Arabic (Algeria)"
1801 = "ar-ma;Arabic (Morocco)"
1C01 = "ar-tn;Arabic (Tunisia)"
2001 = "ar-om;Arabic (Oman)"
2401 = "ar-ye;Arabic (Yemen)"
2801 = "ar-sy;Arabic (Syria)"
2C01 = "ar-jo;Arabic (Jordan)"
3001 = "ar-lb;Arabic (Lebanon)"
3401 = "ar-kw;Arabic (Kuwait)"
3801 = "ar-ae;Arabic (you.A.E.)"
3C01 = "ar-bh;Arabic (Bahrain)"
4001 = "ar-qa;Arabic (Qatar)"
If noProblems occur, you will have the whole system language changed.
hello
today i am going to show you how to change language arbic to english. First you go on
control panel. And then you see there regional languge you can see there lot of languge you.
Now wich language do you want you then you select that's it .
Go to Start-->control Panel--->Regional and Language Options--->select arabic in the drop down for language. also goto the advanced tab and select arabic there.
1. Go to settings option.
2. Check the regional settings option to confirm the country for english language.
3. Then go to Multilingual support, in that check the country option in US english.
4 . Then go to control in Multilingual support and select English with arabic support.
The style in which numbers, currency, dates, and times are displayed isspecified in regional settings.
Tap START > Settings > System tab > Regional Settings.
On the Region tab, select your region and language.
The region you select determines which options will be available on the other tabs.
To customise settings further, tap the appropriate tabs and select the desired options.
And Tap the Multilingual Support then tick "Disable Multilingual Support" That's it you are good to go! Enjoy your Imate! If you need further assistance, let me know. Don't forget to rate me positively! thanks!
reset the phone.. master reset.. on start up, it will ask a long message with "ACCEPT" and "REJECT" as choices. In that if u click "REJECT", it will install the interface in English. If you choose "ACCEPT", it will install in Arabic. --Vidya, India--
