Sony PlayStation® 3 (80GB) Console Logo
A
Anonymous Posted on Jul 14, 2013
Ps3 connection speed internet 80711092 - Sony PlayStation® 3 (80GB) Console
I have an xbox and a ps3 and my xbox has terrible connection to the wifi and my ps3 is connected to the router and has even worse connection thn my xbox! how do i improve my inteernet connection to my...
Sometimes when this happens to my PS3 or Xbox, I turn off my routers for at least 10 seconds then start back up again. Another way to rule out that it is indeed your gaming systems and not lag with your internet connection, I recommend that you run a bandwidth test from your PC first. This will give you an initial understanding of your internet performance. If your Bandwidth test returns a result of a slow connection, this will have a direct impact on your gaming experience. Here is a link to test your bandwidth (or internet connection speed.)
Click here for speed test.
Note: anything below 1mb on your download speed will cause your gaming experience to be poor.
I recommend 3+ meg for optimal performance.
I hope this information helps you.
Regards,
NIco
2answers
Error code 80710092
Try creating a new username and password. This seems to be a common issue currently and people are reporting that this has worked for them.
I have ps3 internet but ps network! dns error 80 something and have been signed out of psnetwork! what do i do ?
This means you've been signed out of the playstation network. A problem with your broadband, not your PS3. Check the connection of the ethernet cable from your router to the ps3. Then switch off at the mains both your ps3 and your router. Leave for 30 seconds then turn both back on. Wait till the blue lights on your router are all steady blue not flashing red or orange. Then turn on your PS3, go to network settings, then internet connection test. This will check your internet connection, and whether or not you're signed in to PSN, and also your internet download/upload speed.
Hope this helps.
LJ
I am connected wirelessly to an 802.11N Network. Why would my ps3 only get 1.1Mbps download time if it's reporting 95% signal strength? I can't even connect to the PS3 store the connection is so bad, i get...
Hi. Since you are getting a good signal in your pS2 connecting to your wireless router. Test your internet connection using this site www.speedtest.net. Your download speed should atleast 80% of the speed that you subscribed. For example, If you availed for a 5mbps connection you should be getting 4mbps or more when you test the connection.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
No Internet connection was playing last night and
Check your downstream speed via the router control panel 192.168.0.1 if there is no speed there is no internet
3answers
Internet connection
call ur isp ur internet may not fast enough
Cant connect my PS3 to internet
you can test your internet speed here http://www.ip-details.com/ ,i test my internet speed and got good result, this provides th ep details at free of cost ,i test the ip details here..
2answers
Can't go online with a ps3 by hooking it up to a laptop. I've hooked up an ether net cable to the back of a laptop that has a built in wi-fi connection but my ps3 will not hook up to the internet please...
ok, first, check your laptop to see if it is connected to the internet. If not, create a connection (go to control panel, then network connections, follow steps) then, go on your ps3 and go to settings, scroll down to network connections, then press x on internet connection settings, pess ok, choose easy, etc. as long as your pc has a connection to the internet, and you have high-speed internet (not dial-up), you will be able to go online.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
