WHEN I TURN THE JET SKI OFF IT APPEARS THE OIL LEAKS INTO THE ENGINE. SOMETIMES IT IS DIFFICULT TO START IT SOMETIMES SMOKES BADLY AT FIRST CAN YOU HELP ME WITH THIS PROBLEM
The oil injection unit on these skis can fail to test you will need to empty gas tank disconnect oil feed line to inlet manifold
then make a mix of two stroke fuel to the correct ratio say 10 liters. poor in to tank and take ski for a run say 10 minutes let it rest and run again if problem persists
it is possible you have leaking or blown crank case seals you will most likely need a professional to test for
i have provided you a link for free shop manual
SOURCE: Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
SOURCE: ISchematics for 89 kawsaki jet ski
Go to the site below where you can see a parts diagram for your specific WATERCRAFT. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
If looking for an electrical schematic this site will not help. You will need a service manual for that.
SOURCE: I have a 1989 kawasaki js 550 jet ski. The engine
Check the ignition coils to begin with and basically follow the wiring back to the stator making sure you have proper voltage at each component, also check to make sure everything is grounded properly, it is very common for the grounds to be corroded on marine equipment. I will have to check but I am sure I have a dealer service/ troubleshooting manual for kawasaki skis, so if you have any other questions about yours let me know.
SOURCE: i have a 1990 kawasaki jet ski that gets hot. the
Running too lean will cause overheating.also has getting hot been true from the time since or before rebuild.? Why was it re-built? To much sealent or wrong seals could cause high temp Also cooling system obstruction from intake needs to be eliminated as cause.
SOURCE: I have a 1998 kawasaki
you mean gas? check fill pipe for any obstruction with a wire hanger. my 96 aint to quick either
What is limp mode and how do you clear it?
ignition switch is frozen or stuck in off position. What would cause this and how do I fix it?
