SOURCE: no screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: I have the slim wall
You drywall is not strong enough to support the 75 or more pounds of TV that you
want to mount. The studs are wood and are 2X4 s and will hold more weight the drywall which is kinda clay between cardboard.
You will damage not only the wall but the TV as well if you do it this way.
Follow the mounting instructions that came with the TV wall mount or have it done by a professional.
SOURCE: SCREW SIZE FOR LG 42 INCH SCREEN STAND
It is usually indicates on manual..
if you don't have manual try to go to retrevo.com..
Usually the common size 1/2 inch wood screw..
