Video Game Consoles & Games Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wii will not turn on. No power to console
Went to play and noticed no red light on. Good power source but wii will not turn on and no signs of power to console. no lights on
Keith Koene
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on Mar 30, 2009
Keith Koene
Expert
Level 2:
Sniper:
Answers
62
Questions
Helped
36465
Points
197
Sounds like you may need a replacement power cord for your Wii.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2614
Points
17
I had an odd experience with this. After a power glitch, where there was a power failure that lasted just a second or two, my Wii would not turn on. It acted as though the power supply failed completely.
While I was trying to get to the power supply behind the TV, the phone rang and a neighbor was calling to borrow my Wii's power supply since he thought his might have failed. So obviously both of ours was affected by the power glitch, The happy news was that he called a bit later and told me that after leaving it unplugged from the outlet (the mains, for you europeans) for a period of time, it started working again when he plugged it back in.
So for those that encounter this, try that before hunting down a replacement.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1314
Points
Will I think that I know something about your question my answer is that your wii might be hacked so your system might turn off
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
1helpful
How do I synce wii remotes
instructions
  1. You will first need to make sure your Wii remotes have batteries. Then, turn on your Wii and go to the Wii menu.
  2. Open the little white door on the front of the Wii game console (this may require using your fingernail). You will notice a little rectangular red button.
  3. Open the battery compartment of your Wii controller, which may require removing the rubber jacket. You will notice a little round red button there.
  4. Press and hold the red button on the Wii game system and the red button on the Wii remote at the same time for at least 2 seconds. I usually hold down the remote button, then press the game console button for 2 seconds because it is easier for me. You will notice the 4 little blue lights on the front of the controller blink many times. The lights will eventually stop blinking and one of the four lights will remain on. The light that remains on tells which number Wii remote you have. The one on the left is number 1. The second from the left is number 2, etc.
If you bring your remotes to a friend's house to play, don't forget to sync your remotes back to your Wii console when you get home.
All the best!
Tsunami Dan
Read more: HERE
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
2answers
Our WII won't turn on no power? Any Ideas?
the power went out and now my wii won't turn on and hte power source is good?
Wii power source probably broken
Plug something else into the adapter to make sure it works, if it works you may have blown the Wii's fuse which will need repair.
Constint blue light
It means WiiConnect24 is on and you have a message. To turn off WiiConnect24 when you are finished playing the Wii, press and hold the power button until the light truns to red.
Wii console will not turn on
Check the Plug in cord and if thats plugged in it might be overheated or in might be fried.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
