Tplink 5210g not reset
A hard reset will remove all your
settings, and your device will be restored to factory default settings.
Do not perform a hard reset unless
you have backed up your settings or you can do the configuration again.
Directly press and hold the reset
button on the rear panel with a pin for approximately 6 to 10 seconds when the
device is running, then the device will be reset and reboot automatically.
Note:
1. Make sure the device is powered on before it reboots completely.
2. After the hard reset, the IP address of the device should be change to the
default 192.168.1.1/192.168.0.1, and the default login username and
password are both admin.
3. Ensure that the IP address of your computer is in the same IP range with the
device. That means your computer should have an IP address like 192.168.1.X/192.168.0.X
(X is in range of 2~253), and the subnet mask is 255.255.255.0, the default
gateway should be 192.168.1.1/192.168.0.1, which is the IP address of the
device
