Greetings - wondered if one of you experts could tell me where to find instructions for programming used corded phone I bought at second-hand store? It's corded, Thomson Consumer Electronics (all searches so far have gone to GE), model number 2-9316A. Can't find any info on it. Works fine, just want to program some family numbers into it. Cordless phones are dying and don't want to lose the numbers programmed in them. What do you recommend? Thank you!
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Re xscatguy's question about inserting a pause... from the manual at for the 2-9315 (http://157.254.235.130/public/15401660.pdf):
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing sequence
when storing a number, for example, when you need to dial 9 to
get an outside line.
Press REDIAL at the point in the dialing sequence in which a
pause is required. Each pause counts toward the 16 digit limit.
I found this info through Manuals Online (http://phone.manualsonline.com/ex/thread/view/idThread/2452777).
Maybe this will help.
To program:
2. press STORE
Manual says. 1.press speaker or lift handset. 2.press store 3. daial the number to be stored 4.press memory location( 1-9 on keypad0 or the 3 emergency quick dial 6.press speaker or hangup.
Hi! Looking for instructions for my grandmother's very old AT&T speaker phone the model number on the top right says 725 - looks like it was a model probably used in offices, where there are 2 rows of pre-dialed numbers in the middle of the face of the phone. We've tried pressing program and retyping in relatives phone numbers but nothing works. Crossing my fingers you can help with this one - thanks!
Need programming instructions for adding new phone #
