Question about Honda 3000 Watt Portable Generator
Need a battery for honda eu3000is
I was not able to start my newly purchased, but used honda eu3000is generator with the electric start. The pull cord worked fine. Come to find out the people I bought it off of had pulled the battery out for some reason. Can I just go to home depot and buy a battery that would be used for an electric start lawn mower or something? Or do I have to buy a factory original honda battery?
Thanks,
Brian
  • 1 more comment
  • brian maffei Mar 29, 2009
    Thanks,
    I will bring it down tomorrow to see what I can do.
    Brian
  • fisherj Apr 21, 2009
    how do I access the battery on the 3000is to replace it?
  • Tim D Pettigrew
    Tim D Pettigrew Oct 26, 2014
    Brian...The Honda eu3000iS uses a Yuasa YTZ10S out of the factory to start the generator. You can purchase an equivalent online the Yuasa YTZ10S is a battery that is widely used in motorcylces and some garden equipment. Shop around they can be found costing in the range of $50 to $100 depending on the website you check. Use a 10mm socket wrench to remove the front cover. Clean the battery slot out and push the retaining strap & wire leads out of the way. Tilt the top of the battery towards you at a 45 degree angle and inset bottom first sliding the battery into its slot. Secure with the rubber strap and connect the positive to positive and negative to negative leads. If looking at the front the positive lead in on the inside! Good luck!
    New Friend:
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
Posted on Nov 25, 2014
You can either purchase the new battery from a Honda Generator repair provider or from Batteries Plus. Both will cost you about $60. They will tell you that a new battery is good for a year or two. It will last longer if you keep it on a trickle charger when not in use. Kind of a pain to remove the three panels to gain access to the battery compartment, but not impossible.
Posted on May 06, 2009
    Novelist:
  • 152 Answers
No, you don't a factory ordered battery.
Yes you can use an after market battery as long as it is of the proper voltage (6vdc or 12vdc) for that system, and it has the proper dimensions (overall size) so as to fit in to the battery tray.
If possible take the generator with you to easily check your new battery's fit, while at the store.
Aduz
Posted on Mar 29, 2009
    New Friend:
I purchased our EU3000IS in 1993 and have made it a habit to run the generator for 30 minutes once a month. The original battery is still fine. I would not recommend a trickle charger unless it is a multi-stage charger designed for the Ah capacity of the battery. In any event you SHOULD exercise the generator monthly to use some fuel, warm it up, and to circulate the oil. If you run it monthly, the charger would be a waste of $$.
Posted on Aug 01, 2012
  • Dick Miller Aug 01, 2012
    This should read 2003, not 1993
4 Suggested Answers
SOURCE:
  • 623 Answers
SOURCE: Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Posted on Mar 17, 2009
  • 83 Answers
SOURCE: electric start will not work
You should remove the battery and charge it up outside the machine then take it to your local auto parts store where they will load test it for free. It must be fully charged to test. Most of the time those small batteries are dead due to the heat produced in the machine. These batteries only run about $30 or less usually.
Note: BEFORE CHARGING if the battery is not sealed ensure the battery water level is good (no exposed plates, usually the water is about 1 1/2" below the top of the holes). Use pure bottled water if you need to add water.
Posted on Mar 30, 2009
  • 154 Answers
SOURCE: honda eu3000is won't start with starter.
replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
Posted on Jun 14, 2009
Start the engine
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it.
BR
Oct 20, 2014 | Honda 3000 Watt Portable Generator
The electric start down not work
At risk of stating the obvious... Is the battery charged and/or connected? Does it at least click like it wants to start?
Jul 28, 2014 | Honda EU3000iS Inverter Generator
Honda EU3000is. 2 year old unit used by electric start at least 5 days a week. My gen has recently stopped staring by the electric start, it turns over but just not as strong as when new, what i mean by...
I have a 5 year old EU300is that would not start with or without the battery. I went through all the usual such as gas, plug, oil, etc. The battery showed 12 volts, however, when tested further it would not hold a load. I bought a new American made battery and now the unit runs fine.
Jan 29, 2011 | Honda 6370C - Parallel Power Kit For ...
Honda eu3000is runs fine with pull cord, but when you use the elec start the starter motor turns but will not engage.
Probably the Bendix needs lube. This is the spiral that the pinion gear runs on.
Remove the starter and inspect to insure the pinion gear is in good shape and the bendix is free to move. also verify that the solenoid throws the pinion out to engage.
You can bench test the starter to verify operation.
Also check condition of the ring gear via the starter mounting hole.
Apr 11, 2010 | Honda 6370C - Parallel Power Kit For ...
My honda eu3000 electric start quit working. I
Hi, You need to check the ignition plug behind to ensure it is still working fine. You will need a spanner for this and unscrew it anticlockwise.
THanks
Dec 09, 2009 | Honda 6370C - Parallel Power Kit For ...
Electric start will not work
Mar 27, 2009 | Honda 6370C - Parallel Power Kit For ...
Mar 08, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda eu3000is won't start with starter.
Mar 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda 3000 Watt  Portable Generator Logo
11,893 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
