The unit has only been in two years and I believe that the lines are being resricted by San Diego's corrosive water.
I was told there is something I can add to the line to clean sediment from lines.
I also would like to add solar system later - any suggestions?
Robert Pike
I would recommend a simple sediment filter housing be installed on the main water line coming into the house. Material cost about $100. Have a plumber install a bypass loop so you can just shut off 2 valves when you need to change it. I always install one with any tankless heater as cheap insurance against such a problem. As far as adding something to clean the lines I would refer to the manufacturer's instructions and use only what they recommend in order to preserve your warranty. For a solar water heater I prefer Velux.
Please rate if this helps-
GlobalTowne.com sells a tankless water heater descaling solution.
Flow-Aide descaling solution quickly dissolves water scale, lime, rust, and other water formed deposits, restoring efficiency to most all appliances. Flow Aide System Descaler is a non-toxic concentrate which is certified to NSF/ANSI 60 for use as a cleaner in potable water systems.
Running Flow-Aide through your tankless water heater periodically will lenghten the service life of your tankless water heater AND improve its efficiency!
You can read their blog entry on how to descale a tankless water heater at http://bosch-tankless-water-heaters.blogspot.com/2009/05/flow-aide-descaling-solution-now.html.
It sounds like I should have done that two years ago !
Thanks,
rcpinspe
