Samsung 6kg front loader (SEW-DW605WB) showing Error code E6
Looking at a buying a second hand samsung front loader, Current owner selling it as mid cycle it stops and shows error code E6. What does this mean and is it repairable?
Thanks
Justin
The washer stopped mid cycle. It sometimes seems like it almost wants to run but then it shuts down and show the error code. I have unplugged it and tried again but still no luck.The washer stopped mid cycle. It sometimes seems like it almost wants to run but then it shuts down and show the error code. I have unplugged it and tried again but still no luck.
AnonymousMar 28, 2014
E6 error message - what does it mean?E6 error message - what does it mean?
You can't post conmments that contain an email address.
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
The "3E" error code indicates that a high current is detected. A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
