The maintenance manual instructions are call or write for instructions but they are no longer in business . I have ordered a new seal but I do not want to attempt to remove old seal untill I see new part. This tiller is a 6HP Troy-Bilt horse model 622139 -Dec 1982 Tecumseh engine
SOURCE: Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
SOURCE: Old Troy Built with model #HH60-105106F. What is
Try partstree.com. It helped me to identify what I needed.
SOURCE: how do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
