Nintendo Wii Console Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wii wired connection for internet access?
Just want to know if i can run ethernet cable from wii to cable box(digital) for internet access, dont want to buy wireless router if dont have to but will
Keith Koene
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on Mar 30, 2009
Keith Koene
Expert
Level 2:
Sniper:
Answers
62
Questions
Helped
36465
Points
197
Sorry to be the bearer of bad news but the Wii does not come with an ethernet cable port. It is only Wi-Fi capable.
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
if this help you please rate me thank you sir.....
2answers
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
1helpful
How to get the internet
Below are simple connection instructions from Nintendo's website on how to connect your Wii to the internet via wifi and an ethernet adapter.
Connect a Nintendo Wii to the Internet through a Wireless Router
1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button
Press the "A" button on your Wii controller to continue from the warning screen
Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
Click the "Wii Settings" box on the right.
5
Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
6
Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
7
Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter
Insert the Wii LAN Adapter into the USB port on the back of the console.
Connect an Ethernet cable from your modem or router to the adapter.
Turn on the Wii console.
Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
5
Select "Connection Status," then "Connection 3: None" and "Wired Connection."
I wish to use internet for my wii yet my alltel wireless huawei cannot connect directly. ive tried using a lan adapter hooked into the wii and an ethernet cable hooked from that to a router, then using...
Turn on the wii, go to settings, go over until you see stuff about internet... select it and from there add your network, type in your password, put your encryption type, and security like WPA or WEP...... You just have to make that your connection and click test connection if everything goes through select use network and enjoy internet on your wii = )
2answers
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • 0helpful
    I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
    I cant get on to the internet
    o.k I to at first did not know how to get on the internet but it is not too hard.
    first there is only two ways to get on the internet using the Nintendo Wii.
    (1) you can easily connect to internet if you have a wireless connection in your home.
    (2) you must purchase a USB Ethernet adapter. this adapter plugs into the USB port on the back of the Wii. You then must have a router with a port available. Run the Ethernet cable from the Wii connector to your available port on your router.
    For either connection you then go into your Wii options ang continue into settings on your Wii. make sure you then chose the arrow to go to the next page. Click internet, connection settings, click connection 1 to set up. chose wired or wireless connection, It will then initiate a test and if all is good you will now have internet connection.
    if you still have problems visit the wii website
    here is a demo :
    Click here
    or heres the link:http://us.wii.com/connect/
    this should help you!
    We have comcast internet and we were woundering if we can hook up the wii to the comcast internet modem through a usb cable if so we hooked it up and we dont know how to get the internet on the wii.
    No you can not directly connect using the usb connection.
    You need to connect either wireless through a router or you need a wii LAN adapter to connect with the Ethernet cord.
    Good Luck....
    Top Nintendo Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Aron
    Sean Wright
    Sean Wright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
