Asking to enter pass word but i for got it
There are actually two codes you can use to reset the password and phone setting.
Below are these codes. Type them in the phone and this should solve your problem.
star button two seven six seven star button three eight five five pound button
and
star button two seven six seven star button two eight seven eight pound button
The security code will be reset to zero zero zero zero.
This will allow you to format the phone easily.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
The only way to get rid of it, is to reset it. Samsung g600 has an Full reset code. look it up. Instead of giving the code,start the emergency call, and give it the code. The default factory-set code should be 1234 or 0000.
SOURCE: samsung sgh g600 security codes
security code is normally 000000 unless changed by someone else
SOURCE: Phone lock needs unlocking - samsung g600
switch the phone on without a sim card,
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone,
if the phone is asking for a SIM LOCK password
then send it to someone who has the equipment to unlock it
SOURCE: Samsung SGH-G600 IMEI reset to zeros after using so-called unlock code
The following worked fine on my Samsung SGH-G600 which was on 02 and now can be used with any sim:
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
JohnJ
SOURCE: How to reset Samsung SGH-G600
you can reset your phone by hard reset method, that is, switch off your mobile and remove the batteries and remain it for one hour and then put the battery inside and switch it on , your phone will be rest
SOURCE: how do you reset the password for j700 when it displays phone fre
try dis 0000 if it dosen't go den go to nerest mobile care coz it need reset by some repair box
PLEASE
RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
