The front left top burner is burning yellow and the burner ports are clean
SOURCE: Oven burner won't ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
SOURCE: Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
