My printer is printing blank pages from more than one printer.. is there a setting or something on my computer back from printing the actual picture?
The Printer printing blank pages, when you have empty ink cartridges, outdated printer drivers, failed print head, and congested nozzles. Follow the steps to fix the printer printing blank pages issue:
·Fix the ink cartridge issue
·Fill the empty ink cartridge tank
·Clean the printer printhead
·Restart the printer
·Update the printer drivers
Read the more steps to fix the Printer printing blank pages issues.
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on
your computer, in your software of choice, or even on your printer, a blank
page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with
your document and ready to print.
Observe your document.
If you see an extra, blank page, you have
created a second page.
To delete the second page, close Print
Preview, go back into the document and eliminate any blank lines in your
documents that you may not need.
You may also find an inadvertent page break at
the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show
Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do
not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print,
within the Print dialogue box.
This is typically done by selecting the
"Print From" option, then entering the page numbers desired.
If your document happens to be ten pages
(without, of course, that final blank page), then enter in the "Print
From" field the numbers "1-10".
This will print only pages 1 through 10,
without an eleventh (blank) page.
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
If new toner was installed and it prints blank pages, please try to print a menu settings page to determine if the problem is part of the printer or an issue external to the printer.
If the menu settings page prints correctly, the source of the problem is external to the printer. To find out if the problem is only with a program, try printing from a different software program. To find out if the problem is only with a particular computer, try printing from a different computer.
If the menu settings page is blank as well, this will narrow the source of the issue to a part on the printer. Please contact Lexmark Technical Support for further assistance.
