I want to fix my lg tv to a bracket but I don't know what screw/ bolts i can use and fix the bracket to the back of the tv thanks.
    Champion:
  • 247 Answers
The screws are philips round head type fine thread u will need to go to a tv bracket dealer shop specify the size of the tv and u will be sold the bracket which comes with the standard screws for mounting
Posted on Jul 11, 2013
  • chris Jul 11, 2013
    No I already have a bracket , it's a TV set with a bracket, but I haven't got the screws, I just need four screws to screw the bracket to my tv, it's not a wall bracket, it's table standing
SOURCE:
  • 476 Answers
SOURCE: vesa screw holes
Most wall brackets are universal for a particular vesa standard, in this case 100mm x 200mm.
This means that the bolts supplied aren't for any particular set.
The Philips 26PF5521D only needs bolts up to about 12mm long.
Try shorter bolts.
Posted on Feb 22, 2008
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
  • 36 Answers
SOURCE: No screws in back of tv
No, the screws comes with the universal mount/ bracket sold separately.
Posted on Jan 13, 2010
  • 26 Answers
SOURCE: mounting it to a tv stand
Use the upper holes. Should be either a 100 x 100 mm (4" x 4") or 200 x 200 mm (8" x 8") or 100 x 200 (4" x 8") on this size television. Most mounts show the mm spacing, so purchase a mount that works with your spacing.
Posted on Jul 06, 2010
  • 302 Answers
SOURCE: My 37" lg hdtv lcd
Their are a lot of things that could be wrong with your TV. The most commond would be your power supply or your signal board. If you look at your power supply carefully, You might see some capacitors that look like they blow up. If that's the case then replaceing them might fix your problem if not then you might have to get a whole power supply. You can get parts for this TV at www.interliquidparts.com
Posted on Jun 08, 2011
I how a 60 inch tv that need screws for the base but don't know what size screws
CALL LG CUSTOMER SERVICE AND THEN GO TO HOME DEPOT ETC.
THEY ARE GOING TO BE STANDARD BOLTS.
Apr 16, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Want to mount tv lg 42lg50 42 in. on wall...which screws you use for drywall
You don't use screws for drywall to hang a TV, EVER.  That's a 50 pound TV.  You should only use the heavy stud bolts that came with mounting bracket and bolt them directly into the studs.  If by some chance the mounting didn't come with them, go to Home Depot or Lowes with the mounting tell them what you're doing and they'll get you what you need.  You are using a mounting bracket, aren't you? If by some chance you're trying to do this without a mounting bracket, STOP what you're doing and get a mounting bracket appropriate for your size television.  Go to Monoprice, they're the cheapest and their quality is excellent.  Meritline is good as well, they just take a little longer to get.  See the video below.
utube.png You-Tube video "lCNyc-KgCDY" placeholder [unremark-end]-->(do not delete) utube.png
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
http://www.meritline.com/tv-wall-mount---c-13552.aspx
Apr 22, 2011 | LG 42LG50 42 in. LCD HDTV
Belt broke...need to know how to open the back
to fix the belt you open the FRONT. I just did this today! Unscrew the dryer vent. Then, with a screw driver, pop the front of the TOP. Then, there are 2 screws with bolt heads... one on each side. 8mm. take those off. pop the front off by lifting up on the whole front panel, as it rests on two brackets.
Jan 25, 2010 | LG Dryers
What specification of bolt is needed to mount the LG 42LB1DR using a VESA wall mount? Thank you.
It can be METRIC M5 or M6, when you buy wall mount brackrt, the kit will come with mounting screws to attach the TV to the brackets.
Dec 10, 2009 | LG 42LB1DRA 42 in. LCD Television
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Vesa screw holes
Try shorter bolts.
Sep 27, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Apr 15, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Ekse
