When the Wii is on, you should be able to go into the menu to reset the remotes. Otherwise when you power them on press the home button and it should give you the option of resetting them as well.
hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
I don't know how to link a wireless nunchuck but you probably have to hit the button on the wii remote where the batterys are and if there's some sort version of that on the wireless nunchuck then you probably would have to hit that and the wii remotes one and pray for the best.
Hopethis works cause if it doesn't well I don't know. :0
hello, i have looked around for you and i beleive all you need to do is press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. and it should work like a charm to get you back to throwin some curve's in wii sports!!!!! i hope i have helped and i hope it works!! let me know how it works
open the battery cover on the wii remote you want to make player 1 press the red button while it is facing the sensor bar. Then open the memory card door on the front of the wii and press the red button on the top. the remote should flash a few times then it will be your new player 1 remote. You can only do this if you have 2 AA batteries in the remote. It will not work with the rechatgeable batterie packs because the remote must have power while you re-synch it.
You need to sync it . . . under the flap on the console where you insert memory cards, there is a red sync button, press that on the console, then on the remote, under the battery cover, there is also a red sync button, press that just after you done it on the console and it should sync.
would you happen to know what controller is the main controller? if so you should have the wii off, then take the controller and point it at the wii and press the power button in the top left corner(on remote) that should do the trick. If you do not know what one was the main one, try doing it with both.
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii. ----John
