Watches Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the battery in a calibri pocket watch ?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 245 Answers
  • Posted on Mar 28, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
245
Questions
Helped
86869
Points
591
Go to the store where u bought the watch....or any store where there sell batteries the normaly will exchange and fit it for u
What size battery is in a phillip crow pocket watch
Pop the back off the watch with a pocket knife and look, they use so many types of small button batteries it is hard to say, better to look at it and record the battery number.
How do I change my ravel watch battery
use a thin pocket knife blade to gently pry the rear snap on cover off.
1helpful
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 • Watches
On my diesel DZ-4108 I changed all of the batteries and the hour and minuet hands are working, but the digital display is not working the batteries are brand new but on digital display what can I do?
I just figured this out. When you replace the batteries, there's the white plastic cover secured with two screws. Remove them and you'll see an area with two exposed 'pads' that says 'reset'. Simply touch them together with a paperclip, screwdriver or whatever and the watch starts right up. :)
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Sweep second hand sticking on colibri pocket watch. How can I correct. I just had battery replaced.
    mcdevito75 here, This is a very common problem easily fixed, when the battery was change the repair prerson could have interfered with the seconds hand bending it ever so slightly so it hits the other hands or it became loose, return to the person who changed the battery, they"ll take the back off and fix that seconds hand. Remember this may be no ones fault so I don"t know about any extra charges for service on your watch. This is just my info to you.
    Pocket watch is wound but still doesnt work
    I would suggest that you change the battery. The battery might be weak, and that could be the reason its not working.
    Take care.
    May 21, 2010 • Watches
    Need to change the battery
    Go to the watch repairing shop near by your place and get it reapired.
    OR let me know your address so I can provide you the repairing center near you.
    Thanks.
    Mzas
    37helpful
    3answers
    Replaceing battery for colibri pocket watch
    Hi, replacing battery can be found on amazon, take a look here: Rayovac Batteries Lasts as Long Costs Less. Wish you best of luck.
    Top Colibri Watches Experts
    NOEL
    NOEL
    ADMIN Andrew
    ADMIN Andrew
    awfashionsseo
    awfashionsseo
    Level 1 Expert
    Are you a Colibri Watch Expert? Answer questions, earn points and help others
