Ricoh KR-5SV 35mm SLR Camera Logo
yvette lake Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Film what type of film does ricoh kr-5sv use
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Ricoh Master 102,366 Answers
  • Posted on Feb 03, 2010
Ricoh Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10430883
Points
622693
It's a 35mm camera, so it uses 35mm film (sometimes referred to as size 135).
You can download a manual from http://www.butkus.org/chinon/ricoh.htm
Ricoh kr 5 super ii mirror
There are some wide angle lenses that will hit the mirror and not allow it to move correctly. Wide angle lenses go further back on the film plane, so they can't be used with that camera. Try a Pentax.
My Ricoh KR-5 won't keep the film door closed. How
The film doors in most 35mm SLR's is spring loaded with a release from the rewind knob. Chances are your spring has lost tension, slipped out of place, or the teeth that grab the door have been damaged. You can always use the handyman's secret weapon (duct tape) to fix the problem, but if you're looking for a more permanent and less gooey and unattractive solution you're going to need to find a shop.
If there aren't any locally, you can find some online, or google KEH Camera if you're not sure who online is reputable. It'll run you $35 for a repair estimate which is waived if you decide to have the work done. Keep in mind some parts, for some cameras, are hard or impossible to come by so your model may or may not be able to be repaired, or may be priced outside of what you're willing to pay to have repaired.
Sep 08, 2011 • Photography
My Ricoh kr-5sv's rewind button is still pressed in after i rewound andd took out the film. how do i get it to pop out again?
The rewind button will usually pop out once you turn your film advance lever. In order for you to be completely familiar with your camera, here's a link to a user's guide in pdf format:
http://www.butkus.org/chinon/ricoh/ricoh_kr-5sv/ricoh_kr-5sv.htm
Hope this helps.
Film advance lever will not advance
Sometimes film jamming in the film can cause the shutter to be very difficult to **** . I had an Pentax years ago that was similar in design to the Ricoh and loved it.
Using a little, but NOT a lot more force may help you to complete the cocking action. Other than that I would remove the film and blow out the mechanism with compressed air. Don't know if this will definitely solve the issue. But hopefully it will.
Best Regards, Mark
I have a ricoh kr-30sp camera will not come on and what kind of film do I use
With the camera turned on, look in the viewfinder. Down on the bottom right side is an LCD display, if it's blank then your camera probably has dead batteries. It takes 2 x CR1/3N or 4 x SR44.
Your film accepts 35mm negative film or 35mm transparency (aka slide) film. It will accept any ISO from 12 to 3200, but in practice all you'll usually need are ISO 100, ISO 200 or ISO 400. You choose the film based upon lighting conditions and the lenses you'll be using, but in general you'll use ISO 100 if shooting mainly outdoors in daylight, ISO 400 if shooting in low light or with a telephoto lens, and ISO 200 is a general all-rounder good for most things. ISO is usually referred to as film speed as higher numbers need less exposure than lower numbers but the trade-off is a less detailed image.
To load film into your camera and to set the camera to match the film ISO setting refer to this link to the manual provided by Norman Butkus. The manual will also guide you through all other aspects of operating your camera.
I hope that I have fully answered your question, but if not please add a comment and I shall respond in due course. If your question has been answered, then please let me know by taking a moment to rate my answer.
2helpful
I don't know how to open the camera to put my film in...
Press the shutter release button to ensure that the shutter is released, then pull up the film rewind knob until the back pops open.
If you need a manual, you can download a PDF one from http://www.butkus.org/chinon/ricoh.htm
1helpful
I can't get the back open to load the film
Hmm, on most SLR's like this one, you pull up on the rewind knob to release the film door
I dont know how to put the film in the ricoh kr-30sp
Please go to this link and scroll down to number 6 under the picture of the manual. It says"insert film". Click on that link and follow instructions! Thank you for using Fix Ya!
http://www.butkus.org/chinon/ricoh/kr-30sp/kr-30sp.htm
Top Ricoh Photography Experts
ExpressFiX
ExpressFiX
ADMIN Eric
ADMIN Eric
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
