The pictures turn out fuzzy & blurry regardless of the setting. I've tried everything from changing the ISO to changing the M.P. setting with the same results. IT EVEN DOES THIS WHEN ON A TRIPOD.
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
