Are you getting Sim card not accepting error message? If it is so then your Sony Ericsson W550i is locked to a particular network. To fix this you have to unlock it. Use unlock code to unlock your mobile from its network lock. To get the code you need to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Mobileunlocksolutions.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
Un-Clocked is temporary, allows free txt and calls for a few minutes.
Un-Locked from a network is what will allow you to use any sim card on your phone.
Go to:
http://www.kingmobilephone.com/pages/remote-unlock.php
No need of disturbing your self to solve this problem check this site www.gsmsolution.com
SOURCE: MY Song Ericsson W580i T-Mobile ask Insert correct sim card
I was sent a Song Ericsson w580i T-mobile from my uncle from Uk and is not accepting my sim card is complaining that I should insert correct sim card, I would really appreciate if i can get a software to enable it work with my sim card.
