Replaced drive belt and reinstalled blade clutch. blade clutch is now building a tremendous amount of heat. seems to be engaged even when disengaged.
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Install bracket
Do they have to be in different positions?
blade not working
i need a manual for a john deere model SST16 lawn mower
i need manual for john deere lawn mower model SST16
drive belt replacement
