Kenmore Elite 45986 Front Load Washer Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get a F 11 code on my machine and it won't start. Manual says it's an electrical issue. Anybody have any experience with this problem? Kev
  • Crapofa wash Apr 03, 2009
    Piece of **** washer.. F-11 code almost every load of wash.. Tech guy could not find a problem.. Will never buy a Kenmore product again
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Mar 30, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
Helped
120878
Points
632
Kev a bad ccu(main control) will cause that.
Atiston front loading washer flashes f-11 code
Check the Motor and Drum: Sometimes, issues with the motor or drum can trigger the F-11 error. Inspect the motor and drum for obstructions or mechanical problems. It's possible that something is impeding their movement.
Verify Water Supply: Ensure that there is no issue with the water supply. If the washer doesn't fill properly during the spin cycle, it can lead to an error code. Check for water inlet valve problems or water pressure issues.
Verify Electrical Connections: Double-check all electrical connections and wiring, not just those accessible from the bottom panel. Issues with the control board or other components may not always be visible from the outside.
Sensor and Switch Inspection: Look for any faulty sensors, switches, or pressure switches that might affect the spin cycle. A malfunctioning sensor or switch can lead to the error code.
Professional Service: If you've thoroughly checked the visible components and the problem persists, it's advisable to contact a professional appliance technician who can perform a comprehensive diagnostic and identify the root cause of the issue. They may need to use specialized diagnostic tools to pinpoint the problem accurately.
The F-11 error code can sometimes be challenging to diagnose because it can result from various underlying issues. If you've exhausted your troubleshooting options and the problem persists, professional service is likely the most effective way to address the issue and get your washer back in working order.
12helpful
2answers
My machine have error co3ff
Never seen this code before and I have 27 years of experience on Minolta copiers.
Here is the info contained in the service manual although I doubt it will help.
C03FF - Improperly set Adjust Mode 11
• An incorrect setting is made of Adjust 11
2helpful
Manual Guide for Juki Frou Frou HZL-11
Visit us at www.ifixmachine.com
Error E-11
most common cause for this problem is defective electrolytic capacitors on the mechanical interface board. a good electronic tech should be able to replace them.
Alexander
vince
