Google Chrome Logo
Anonymous Posted on Jul 09, 2013
I keep on getting 404 error. URL \-7890*sfxd*0* how do I fix this
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 59 Answers
  • Posted on Jul 09, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
59
Questions
0
Helped
9900
Points
106
How To Fix the 404 Not Found Error
  1. Retry the web page by pressing F5, clicking the refresh/reload button, or trying the URL from the address bar again.
    The 404 Not Found error might appear for several reasons even though no real issue exists, so sometimes a simple refresh will often load the page you were looking for.
  2. Check for errors in the URL. Often times the 404 Not Found error appears because the URL was typed wrong or the link that was clicked on points to the wrong URL.
  3. Move up one directory level at a time in the URL until you find something.
    For example, if www.web.com/a/b/c.htm gave you the 404 Not Found error, move up to www.web.com/a/b/. If you get nothing here (or an error), move up towww.web.com/a/. This should lead you toward what you're looking for or at least confirm that it's no longer available.
I keep getting a 404 error when I try to download the Gemmy Santa manual
The typical trigger for an error 404 message is when website content has been removed or moved to another URL
Dec 06, 2023 • The Toys
How to remove google 404 error?
A 404 error is an HTTP status code that indicates that the page you were trying to reach on w website couldn't be found on their server. There are billions of user's faces this problem at every second and minute and no can escape for that. There are multiple reasons behind the error 404 code and it never means you can't fix this problem. But there are many users always ask how to remove Google 404 error and if you are one among those, then you can easily fix this problem by applying some easy troubleshooting steps.
Here are the steps to fix 404 errors on Google:
·Check the URL: Sometimes entering an incorrect URL may also cause several of error including the 404. So make sure that you have entered the URL of that particular website correctly.
·Refresh the page: You can also refresh the page for that you are confronting this error by pressing the F5 key.
·Clear the Caches: By clearing the caches and history of that page you may also fix the problem of 404 errors in a very simple manner.
·Check the internet connectivity: Make sure that you are working on an active internet connection because sometimes bad internet connectivity also occurred several problems.
If you are still confused that how to remove Google 404 error even after applying the above-described steps, then you can contact the customer service team and avail the instant assistance to fix this problem.
Get more info from here:-
https://www.tecask.com/blog/how-to-remove-google-404-error
3answers
How do i fix error 404 on internet explorer windows 7
do the latest updates for windows and try again and if this does not reslove the error try contacting the webmaster of that page
Google 404 that's an error What is 404?
A 404 error is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Another possibility is if a website has moved a page or resource but did so without redirecting the old URL to the new one. When that happens, you'll receive a 404 error instead of being automatically routed to the new page.
Note: Microsoft IIS web servers sometimes give more specific information about the cause of 404 Not Found errors by suffixing a number after the 404 as in HTTP Error 404.3 - Not Found which means MIME type restriction.
Http error 404 not found
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Try another URL or check with the site your are trying to contact to see if they are still active. Hope this helps.
WHEN I TRY TO USE GOOGLE, i GET THIS MESSAGE URL /-7890*sfxd*0*sfxd*0 . WHAT IS WRONG?
This is not normal. You can try clearing browser settings, and disable any add-ons. Definitely run a thorough virus scan.
404 error
Try to retry the web page by pressing F5
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
2answers
Slotomania will not open - error 404 nginx/1.0.8
No matter the reason for the 404 error, there is plenty you can do to try to get to that page you were after:
Retry the web page by clicking the refresh/reload button or trying the URL from the address bar again. The 404 Not Found error has been known to appear on occasion even if there is no real issue so a simple refresh will often load the page you were looking for.
Move up one directory level at a time in the URL until you find something. For example, if www.w.com/a/b/c.htm gave you the 404 Not Found error, move up to www.w.com/a/b/. If you get nothing here, move up to www.w.com/a/. This should lead you toward what you're looking for or at least confirm that it's no longer available.
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
