If UPS is displaying "Site Fault", it is doing its job correctly. You need to check the wall receptacle. Probably hot and neutral reversed, or the neutral and ground are reversed, by whom ever installed the wall receptacle. You need to have the plug-in for the UPS intact, i.e. the ground pin must not have been cut off. If an extension cord connects the UPS to the wall, thge cord must be working correctly.
Site fault = Live and Neutral connected wrong way round (polarity) OR Too much voltage between Neutral and Earth.
Solution: Check line and Neutral connections + Settings-Site fault test-disable (ship use etc)
Hope this helps.
