pleou hank yase if you have list oif codes used for nmy sim to unlock puk code tpleou
You can't post conmments that contain an email address.
No Interest if Paid in Full within 6, 12, 24 Months: Available on purchases on Samsung.com charged to a Samsung Financing Program Account. On purchases of ...
The E4 is an error code. What the washing machine "is trying to communicate" to you is that it has detected a load imbalance at the clothes being washed; thus it won't be able to spin at full speed. Maybe it stops waiting for you to distribute the clothes more evenly. See more about error codes at http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html.
This is a list of fault codes for whirlpool machines. I don't know if it is complete, but if you scroll down the page you will come to the duet sport washers. Those maybe the codes you'd use. However nowhere in the list is a code that matches yours. Try unplugging the machine, opening the control panel and give all wires and connectors a wiggle. It is also likely that Whirlpool taped the codes to the inside of that panel or on a bottom panel of the machine. If the code doesn't go away give me the full model number. You can usually find it around the inside of the loading door or back of machine at the top. Hope this helps.
Hello there again here is some more info for you Whirlpool Washer Troubleshooting: Error/Fault Codes
Whirlpool Washer Troubleshooting has been made easier since newer
Whirlpool washers generally display a consistent range of error codes
(or fault codes) when problems develop so that owners and service
personnel can quickly troubleshoot the problem and fix it easily. The
Fault codes address a wide range errors that occur with Whirlpool
washers, everything from water and power problems to basic maintenance
routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Hi I have included a list of error codes for the Samsung washers. Please look it over and check your machine for the code to match it with the list. Most coded have a number besides the letter E and I need that also to correctly diagnos the issue. Once you get the code and determine the issue I will do my best to give you a diagnosis of the problem
Thanks
pleou
