Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound coming from subwoofer
I have a Denon AVR-589 and klipsch speakers & Sub, No sound coming from sub please help!!
pete-ny
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 13, 2009
pete-ny
Contributor
Level 1:
Answers
Questions
0
Helped
538
Points
I have the same problem. When I run the calibration I can hear test tones coming from the sub but when I play movies or music- nothing or very low. I've tried overiding the settings and bosting up the sub to +12db but no difference. Its like its turned uff disabled of the crossover is too high.
Anonymous
Level 2:
Sniper:
  • Expert 51 Answers
  • Posted on Mar 29, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
51
Questions
0
Helped
21278
Points
117
Sure we will help you, but you need to check these,
1.Wiring connection from dvd player to home theater system,
2.Wiring connection of a home theater amplifier to speakers,
3.While playing the Original dvd the 5.1 audio you have to manually enable.
and if you still find any difficult please feel free to contact.
My subwoofer input is not working!
Check that the front speakers are set as "small" in speaker setup menu and sub="yes". let me know what you get.
My sub ksw10 do not work with avr589.sub is fine.av receiver works on all 5 channels.with the remote i am unable to adjust all the parameters.
http://usa.denon.com/DocumentMaster/US/AVR-589-OM-E_105A.pdf you'll need to access the receivers speaker Set-up menu. you can download the user manual here. my opinion is that your speaker setup in the menu is not correct. make sure that you have Subwoofer yes selected in the menu, also if you selected ( Large ) as your left and right Main speakers it will not allow you to select Subwoofer ( yes/no ). you must select ( Small ) and then select Subwoofer Yes. also you can connect all speakers and perform Auto setup and it will recognize the sub when a test tone is emitted.
1helpful
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
My Denon AVR 589 does not seem to send any signal to my sub, I have try another working sub and it does the same. I just notice this week that my sub was not working. I have check on the amp setting and...
Is there a switch on the back of the receiver that will switch the sub signal from digital to analog? And the same switch might be on the subwoofer itself.
Hope that helps if not just reply back.
Thanks
Unable to get my sub to work with my Denon AVR 1506 Receiver
Did it ever work? Are you certain the sub is getting a signal. It has to be defined. How about the speaker levels adjustment? Did that work? Give us a clue.
1helpful
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
1helpful
2answers
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
2answers
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Tuning speaker system denon avr 2400
You need to check on the operation of your receiver regarding the use of the subwoofer output line. If it does not satisfy you, better get a better receiver or A/V control pre-amp system with lots of features in the subwoofer circuitry. Google (internet) might help you with your specific model.
 Grubhead
Grubhead
SmartAviator
SmartAviator
