When we start either oven or microwave it clicks off like a short with the letter PF coming on the screen.
See the diagram attached and fix it. God bless you
SOURCE: Whirlpool Electric combination Microwave and Oven
I could have been more specific with a model number, but if this general
answer doesn't do the trick, feel free to contact me with your full
model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many
components. See the example photo at the bottom of this reply.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Make sure that the program controller is working if not check
power - step down supply, the pads are responding- if not faulty pads- or the
door switches, if the switch contact are not good then it will not trigger the
processor to switch on the waveguides. If the lights or fan work without any
display or action of program being triggered to start then it can be a possible
fault on the main board or the processor. Sometimes insect secretion can short
the board and display panel and so the processor can work in such an erratic
manner. If so clean, solder and reset the board. Now identify the parts by
clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating
please do not switch on unless you have confirmed the fault. It is possible
that the Magnetron is faulty, the temperature cut off is faulty or the main
capacitor is short. It is also quite possible that insect can get into the oven
and create soft spots. When you switch on these will create a short and make
the voltage jump and in the long run damage the magnetron. Check this link to
know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
