Question about Denon AVR-1905 Receiver
Receiver blowing fuses
AVR-1905. Powers up (green light solid).Some indicator lights. No sound. No display. Blows 8A 125V immediatly. What are probable causes? What components need testing. Have schematic.
  • 1 more comment
  • Randall Fleetwood Jul 10, 2013
    successfully repaired shorted transistors & related resisitors on this unit 3-4 years ago. Then was in protect mode not fuse. Think your solution likley correct.Curious as to why fuse now & not protect as before.
  • Steve K Jul 10, 2013
    hard to say. Possibly if it's the same channel as before, the new resistors are rated for a higher current and are not blown. Have seen many times where either the fuse blows and the resistors are fine, or the resistors burn up and the unit goes into protect and the fuse is fine.
  • Randall Fleetwood Jul 11, 2013
    thanks Steve. you have been very helpfull
    Genius:
  • Denon Master
  • 1,054 Answers
Problem is most likely shorted output transistors. These are the large transistors mounted on the heatsink. When these go short, they usually take out some the adjoining resistors in that channel.
Posted on Jul 08, 2013
SOURCE:
  • 5 Answers
SOURCE: No sound on cable TV for Denon AVR 1905 Receiver
Audio setup on the TV, needs to be swited to Fixed or both, this is usually the same on all T.V.s....
Posted on Aug 25, 2008
SOURCE: avr receiver
I had same problem with my denon avr 1601.I have fixed it by myself by favour of Haapy Yogy. Thank you.
Posted on Feb 19, 2008
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: how to hook up xbox to denon avr1905?
I've hooked up an xbox to the front aux jacks with no problems. you can change the device to use the aux through the selector knob.
Posted on Mar 21, 2008
  • 93 Answers
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Posted on Nov 06, 2008
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
AVR 3700 no sound
do headphones work with or without speakers attached? does unit light up? Check fuses. If breaker pops, or replacement fuse blows, it needs repair.
Nov 27, 2013 | Harman Kardon AVR 500 Receiver
Sony str dh520
If it's blowing the fuse, then there are probably shorted output transistors in the amp that need to be replaced.
Jul 10, 2013 | Audio Players & Recorders
Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Dec 18, 2009 | Sony STR-DE945 Receiver
I have a harman kardon avr 745....looks frozen
My device is AVR 645, but AVR 745 has the same power regulator board and you could check, if the problem is there.
(AVR 645 volume blue light was not pulsating)
When device is turned on, it shows all display indicators,
no blue light on volume button and no response to any remote or front panel buttons.
Reason for failure:
No 3.3V and 5VD voltages.
I checked bridge rectifier D701 on power regulator board.
One of the diodes was shorted. Also fuse F702 was blown.
Original D701 is KBU6G, but because regulator board is a bit difficult to get out, I decided to use KBU8G. The only difference is Amps rating 6A versus 8A.
Be sure to use SR-5-3.15A fuse to replace F702 and use heat sink paste (you know where) when board is reinstalled.
There is large heatsink in the middle of the receiver. Power regulator board is mounted on the right side of that heatsink. It is down there near the front panel and to get it out you most probably first have
to remove two PCBs hindering access to some regulator component screws. Here are pictures to clarify situation:
harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-0.png harman-kardon-avr-745-looks-frozen-igzigj2finjgh1nndvq1cugs-5-1.png
Oct 26, 2009 | Harman Kardon AVR 140 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Hi again,
Any new developments?
May 25, 2008 | Denon AVR-1905 Receiver
Jan 20, 2008 | Denon AVR-1905 Receiver
Denon AVR-1905 Receiver Logo
190 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
