Use unlock code to unlock your Sim card in Sony Ericsson Xperia X10 Mini. Get the code form the site Onlinegsmunlock.com ,and unlock it using unlocking instructions which is given in the site itself.
SOURCE: how do i copy contacts
phone book pe jao option select karo copy to sim ok karo all contact ok karo dushra phone pe eesi sim ko lagaoo aapne aap so hoga
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
You can Unlock Your Sony Ericsson X10, X10 Mini, X10 Mini Pro, X8, M1 Aspen, W100 Spiro to use desired network sim from home, using the cable as supplied with your phone.. Fast and simple,
This server will also unlock models that have used all unlock code entry attempts up too !!
You can now unlock new Sony Ericsson Phones in seconds from home, no need to send the phone to us.
Use our special unlock server and you can unlock the following models easily and safely.
Once unlocked you can use your desired sim card from any network.
more info @ http://www.fonefunshop.co.uk/Unlocking/unlock_sony_ericsson_x10_server.htm
