Coffee Makers & Espresso Machines Logo
Posted on Mar 28, 2009
Capresso c3000 malfunction 8
When I start up my capresso c3000, I receive a LED message that says ''Malfunction 8''.
5 Related Answers
Anonymous
  • Posted on Dec 30, 2007
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
macdara dunne
  • 46 Answers
  • Posted on Feb 09, 2008
SOURCE: jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
Yves
  • 17 Answers
  • Posted on Dec 29, 2008
SOURCE: malfunction
problem 8: malfunction of the brewing unit. you can't fix it yourselve.
Anonymous
  • 60 Answers
  • Posted on Jul 27, 2009
SOURCE: Malfunction 8 - Good Cleaning of the Unit, but how to open?
You must remove the 4 oval screws on the back panel, then lift up the top panel. Then take a good grip in the left panel (seen from behind) and pull back. The other panel you use your fist and hit lightly backwards, it is ligthly snapped in the front panel. Then you will have free axcess for cleaning.
Anonymous
  • 4 Answers
  • Posted on Mar 27, 2010
SOURCE: Capresso C3000 Mega-weak coffee
I have a Capresso fo 7 years now, had few problems, but always solve them.
If youe machine does all the functions properly, but doesn't give you coffee, you should check if everytnhig goes into the grounds tray. If that's the case you may only have a broken "O ring" inside the pressing element. It makes the coffe, but throws it away instead of filling the cup. I had that problem, and it was the "O ring".
If the grounds dunped on the tray are dry, you're looosing the water in the back, probably on the relief valve.
Hope this helps!
1helpful
I have a malfunction 8 that shows up
malfunction 8 is the brewer piston oring. one from a franke saphira will work.
4helpful
How to fix error message 8
DISPLAY SHOWS MALFUNCTION 8 Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
7helpful
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
4helpful
Service 8 on Capresso 1300
The gears inside are clogged with coffee grounds. The machine will need to be taken apart carefully, and the gears cleaned of the coffee. I just did mine a C3000, and you will have to be careful to remember how all the parts go back together. This takes a T15 hex key for the screws. Good luck.
Malfunction 8
The brew unit having problems with positioning it self. Use your finger and clean out all used ground from the brew unit you can find. Start the cleaning program with tablet, hopefully you will get around the error code.
2helpful
I have a capresso c3000 and one day it just wont turn on anymore. any suggestions?
We had the same problem. We unplugged the unit from the wall and then plugged it back in again. For us, it was as simple as that.
3helpful
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
