Electrical Supplies Logo
cruz murillo Posted on Jul 08, 2013
Light switch Light Switch Won't Work, How do i fix it?
A
Anonymous
Turn off the circuit breaker for that circuit & replace the broken switch
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1011
Points
11
Sounds like the switch its self is broken REPLACE IT make sure serciut breaker is off first
2answers
Brake lights won't work
Check the voltage or the connection.
__________
Multi-Cardiag M8 CDP for car and truck
Cabin light won't turn off when doors shut on Holden combo
Push the headlights switch in. The switch doubles as the cabin light switch and it easy to activate the cabin light when turning the headlights on or off
Headlights, tailights and dash lights won't work on my XR6. Headlights work on auto mode but not normal mode. Any ideas?
check your negtive wire from battery to ground ,in other words, to body of vechile.
My 2004 Chevy Impala right head light won't come
There are right and left fuses for the headlights. The dimmer switch and headlight switch provide the ground circuit.
Do you have power at the fuse ?
1helpful
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
2answers
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
1994 gmc jimmy headlights wont turn on
go to an accredited auto electrician for electrical work
it may be a switch problem but I think that there is no power to the light relays ( switch or fuses)
if that model has a light control module , it could be that
1helpful
Car will not go into gear while running
Check your brake lights. There is a switch on the brake pedal that actuates a release solenoid for the shifter. If this switch is bad, it won't shift out of gear and most likely the brake lights won't work.
Replacing this switch should fix your problem.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
