M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
