Took it apart and cleaned the blower fins and vent, (wasn't really bad) Drum spins easy, the blower spins with the drum.. put it back togeather and ran it with the same results, even without the exhaust pipe connected. I saw 2 sensors inside the vent pipe and made sure they were clear, but i'm starting to suspect one of them might be an issue.. Can someone tell me which sensor i should replace? or is it something else possibly?
Samsung service manuals do not indicate a TO are you sure check my files: samsung https://drive.google.com/drive/search?q=samsung%20dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Will run for about 4 minutes then stopps with the "TO" code..
Thermister was Open(bad), had a new $10 thermister shipped to my door and i'm up and runnning.
