HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD
Player to only those DVD discs that do not exceed the rating you specify. When
the Parental Control is set, DVD discs that support this feature will play only
after the password has been entered. However, typically only discs produced by
major entertainment companies support Parental Control. Discs not supporting
this feature will be "immune" to Lock-Out.
When you attempt to change the Parental Control setting, you are
prompted for a password. This of course makes sense, as this option would be
useless if your kids could enter the Setup Menu and disable it! If there is no user
password set, you'll be prompted to enter a new password. Choose a 4-Digit
numeric password and write it down in Case
you forget it. Key in the password and press ENTER. After the password is set,
press ENTER on the CHILD option. You can choose from 8 levels of Parental
Control, corresponding to the standard rating system in the USA. The available
levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the
default factory password. The procedures to change an existing password or
enter a new password are the same - you
must enter the OLD PASSWORD, then key
in your new password twice to confirm. If you are entering a new password, or replacing a password you
have forgotten, use the factory default
password of 3351 as the OLD PASSWORD. If you are changing a previously entered
password, you may enter that value as the
old password.
A. Remember to keep
in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password
written in a safe location as a reminder if needed
Ajin
If you wish to have more details check these linkshttp://electro-medical.blogspot.com/https://www.facebook.com/electromedservi...
SOURCE: Cyberhome CH-LDV 712 Portable DVD Player
there is but you have to go to the company who made the player and ask for help I've searched net for help but no luck but if you know of any body who has same player then they might help sorry for not helping on thit one but I'll try and help with future problems
SOURCE: How do you reset the parental control code?
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
SOURCE: JVC XV-M555 DVD player has the parental control
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
SOURCE: Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
SOURCE: Parental control password for HM600D DVD Player
The default password is using the FAST FORWARD AND REWIND buttons, it is forward, back forward, back.
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
